-   Dirtbike Lounge (https://forums.off-road.com/dirtbike-lounge/)
-   -   Cylinder head bolt leak? (https://forums.off-road.com/dirtbike-lounge/17028-cylinder-head-bolt-leak.html)
Drew K1500 02-13-2000 10:07 PM
I recently rebuilt my DR350s top end and replaced the head gasket. Now it leaks oil out of the left front Cylinder head bolt. There are no cracks at all. Does my gasket need time to seal? This is a new problem to me.
**DONOTDELETE** 02-14-2000 10:00 AM
Re: Cylinder head bolt leak?
Drew, is that L. front stud/ bolt either a top end oil feed or return path? I'm not familiar w/ the oiling system on your bike, but I know some of the other 4-strokes utilize the cylinder studs and/ or oil passages(usually for delivery) close to the studs, and they usually have O-rings in addition to the main gasket, or copper crush rings as part of the gasket. Some gaskets do have a heat-activated sealant built into them, so it has to reach normal op. temp. at least once, but it shouldn't be leaking now and if it's delivery oil under pressure, be careful that the top end doesn't run dry. Bob
Drew K1500 02-14-2000 02:35 PM
Turns out that the crush washer on the bolt was installed up side down. Its a very hard thing to miss if your not paying attention. The bottom is perfectly flat and the top is barely rounded. Also a little dirt was stopping the washer from sealing completely. Guess thats what happens when your in a hurry.
