Re: KTM 300, thoughts on pipes
from what i know you really can't lighten a flywheel...unless it had flywheel weights put on them then u can take them off...as far as gettin power of a CR250, no, your not going to get that, especially if you put a low end pipe on it, cr's hit hard mid-top end, most mx bikes don't ohave alot of low end....as far as low end i'd say go for the gnarly, i rode a CR250 that had a gnarly pipe on it, it was pretty sweet, gave it nice low end and a good mid range hit...as far as new silencer it depends on if that pipe will fit in with the stock silencer or not....
