xr 350 83 - Off-Road Forums & Discussion Groups
Dirtbike Lounge Hang out and talk two wheels. For Tech and Racing specifically, see those forums below.
post #1 of (permalink) Old 02-18-2002, 12:59 PM
xr 350 83
topend needed. piston ,rings,wrist pin,gaskets, valves,springs, retainers. $ and where
now! want to be ridin by next weekend
post #2 of (permalink) Old 02-18-2002, 05:50 PM
Re: xr 350 83
Try http://www.xrsonly.com
post #3 of (permalink) Old 02-19-2002, 07:26 AM
Re: xr 350 83
they only have oversized pistons there, and they dont have the valves.
post #4 of (permalink) Old 02-19-2002, 09:12 AM
Re: xr 350 83
Their site is hard to navigate, the stuff is there, the valves anyway.
But are you sure you need valves? Or are you just covering everything to be sure? Which is a good thing but will be expensive. If the valves aren't burnt, bent or pitted then I'd reseat them, clean everything up, change the valve seals; guides too if need be.
Check the spring length to see if it's within tolerance. Check the cam lobes for excessive wear, rocker arms etc....
DO check the cam chain length to see if it's stretched and replace it and the guide too. If it's all apart you might as well....
You might try http://www.troy-racing.com for parts.
Good Luck
post #5 of (permalink) Old 02-19-2002, 12:52 PM
Re: xr 350 83
all the valve componentry i need from service honda is 169(everything), gasket kit is 30$
all i need now is a piston kit. gonna look that up tonight on the microfiche.
the xr 350 had a valve hit the piston and kank up the head. i have another head that needs all the coponentry, minus rockers and minor things, has a cam. all lobes are good.
the other piston has a dent obviously.
ya see the bike was good then the valve thing happend. my bud bought it apart with a extra cylinder and head. so i now need the parts for the spare head. he doesnt know what is good or bad with the spare head springs and stuff. i dont know all the details ,he just told me the parts i need as this was his project before i stepped in. he said i might get away with only needing two valves. we are going to go over it tonight.
i am also thinking about the dual sport kit through bajadesign to make it street legal, but thats down the line, as this was my original intent with the 600L
i also am looking for a front end of a 84 xr, they had disc brakes that year up front and mine has drum. if i can get it cheap enough i will do it.my bud has a 84 and my other bud has a 85. all xr 350's
post #6 of (permalink) Old 02-21-2002, 08:07 AM
Re: xr 350 83
i ordered, piston,rings,valves,guides,springs,gaskets,cam chain guide, oil filter.
tore the bike down to the frame, pullin the motor tonight, parts should be here wednesday. regreasing the shock linkage and steering head bearings. has a new seat cover that has to be put on. shock and forks are good. the frame and swingarm is in really good condition. this bike is gonna be really nice when done. it also has a supertrapp. need some misc shiz like air filter,bolts and stuff. i also need the right side panel. hopefully i can get a used one of ebay.
keep ya posted
post #7 of (permalink) Old 02-21-2002, 09:25 AM
Re: xr 350 83
Welcome to the world that goes thump. [img]/wwwthreads_images/icons/smile.gif[/img]
post #8 of (permalink) Old 02-21-2002, 09:44 AM
Re: xr 350 83
I found some panels at Maier but they're for an '85 and they're $70.65. XR's Only say they've got the OEM plastic for older models but no price.
post #9 of (permalink) Old 02-21-2002, 01:40 PM
Re: xr 350 83
maier sucks, thanks though
i gonna prob end up gettin off ebay
post #10 of (permalink) Old 02-25-2002, 09:59 AM
Re: xr 350 83
wow, the manual says 31 hp for a 83' pretty impressed and 247lbs dry. not bad
well i regreased the rear liknkage, new front wheel bearings
. the air filter metal cage has this screen in the back. so i cut it all apart. there was 3 diff screens in there,talk about restrictive. hoping to have it all together by saturday,fingers crossed
