🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics
Diode Dynamics is excited to announce our Stealth LED Light Bar Kit for the 2016-2019 Toyota Tacoma! Computer-designed specifically for the Tacoma, this LED light bar kit secures a 30" Stage Series LED Light Bar using factory mounting points. There is NO cutting or drilling needed!
The included steel powdercoated brackets allow you to easily mount the 30" Stage Series LED Light Bar in the factory lower grille opening. Again, these brackets use OEM mounting points, so you won't have to modify your Tacoma! This Stealth LED Light Bar Kit retains the factory lower grille for a clean, OEM-like appearance. Additionally, if preferred, the lower grille can be modified to make the light bar more visible.
Features:
Diode Dynamics Stage Series Light Bars have been designed using optical simulation modeling, for maximum functionality. Their custom-engineered TIR optics provide FAR more usable light output than much larger, heavier generic LED light bars. Depending on your auxiliary lighting needs, you can order our Stealth LED Light Bar Kit with a white or amber light bar, with the following optic options:
Driving: The Driving pattern was designed to supplement your high beams. Rather than a simple "spot" pattern, the Stage Series Driving pattern has a rectangular 20Wx8H degree pattern that is far more useful for directing light downrange at high speeds.
Flood: The Flood pattern was designed to provide uniform, even illumination and a full 80Wx50H degree spread of light. Unlike generic "flood" light optics that are simply a heavily diffused spot, our flood optic is a true optically designed spread, resulting in the biggest spread in the industry! It is perfect for lighting up anything at low speeds, a backup or reverse light, or to light up a worksite.
Combo: The Combo pattern combines both the Driving and Flood optics. It shines light downrange in a focused, rectangular 20Wx8H degree pattern while also illuminating area around it in a full 80Wx50H degree spread. The Stage Series 30" Combo Light Bar features three driving lenses in the middle with two flood lenses on the outer edges.
Each Stealth LED Light Bar Kit features everything you need to install it on your 2016-2019 Toyota Tacoma, including:
Installation: Installing our Stealth LED Light Bar Kit is simple and straightforward, requiring only basic hand tools. Check out our step-by-step installation guide for detailed instructions, or watch the install video below!
Fitment:
Diode Dynamics Stealth LED Light Bar Kit for the 2016-2019 Toyota Tacoma is proudly engineered and tested right here in the USA, and is backed by our 3-year worry-free warranty! Want to check out more LED lighting upgrades for your 2016-2019 Toyota Tacoma? Click here!
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Jake H.
Diode Dynamics
Features:
- Direct fitment on 2016-2019 Toyota Tacoma.
- Allows you to mount one 30" light bar in the lower grille opening.
- CAD-designed for perfect fitment and OEM-like appearance.
- Utilizes existing mounting points for easy installation - no cutting or drilling required.
- Highly durable powdercoated steel construction.
- Plug-and-play wiring harness included to power light bars.
- Two (2) Application-Specific Heavy-Duty Steel Brackets for Installation on 2016-2019 Toyota Tacoma
- One (1) SS30 Stage Series 30" Light Bar
- One (1) Heavy Duty Single-Output Harness
- All Necessary Hardware
- Installation Guide
Fitment:
- Fits all 2016, 2017, 2018 and 2019 Toyota Tacomas
- Fits all trim levels including Limited, Limited RWD, SR, SR5, SR5 RWD, TRD Off Road, and TRD Pro
Thanks for looking!
Jake H.
Diode Dynamics
