Squeeky springs - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-05-2001, 01:03 PM
GTA
Squeeky springs
I having a hell of a time getting my front coil-over springs to stop squeeking on my Sportsman. I've jacked it up, cleaned between the coils, then sprayed lubricants between the top few coils(mobil-1, silicone, WD-40)I've tried several. After a day or two, it starts squeeking again.
It's very embarassing to ride around or even climb on and hear this annoying sound. Does anyone have any suggestions or ideas?
Gearheads do it greasy!
post #2 of (permalink) Old 07-06-2001, 08:06 PM
raptor_rider
Re: Squeeky springs
your signature says it all, spray lubricants evaporate, you need to take it apart (once again) and clean them up really clean then use a molly grease , grease wont evaporate
Ride hard, Lifes short
post #3 of (permalink) Old 07-06-2001, 10:37 PM
Kyron's Avatar
Re: Squeeky springs
It's not the spring thats squeaking... it's the pivots
You need a thneed
From Once-ler Industrys
Kyron is offline
post #4 of (permalink) Old 07-08-2001, 01:41 AM
raptor_rider
Re: Squeeky springs
do the same to the pivots, clean then grease
post #5 of (permalink) Old 07-09-2001, 09:53 AM
GTA
Re: Squeeky springs
Thanks for your responses. I assume you mean the rubber bushings atop the strut mounts when you say pivots. I'll give it a try.
post #6 of (permalink) Old 07-09-2001, 01:32 PM
Re: Squeeky springs
I have had luck spraying chain lube on the rubber bushings on mine that are on top of the strut. The chain lube lubes the rubber o rings on the chain so i tried it there and it works good, make sure you get ALL around the rubber.
