Engine is popping, HELP - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-20-2001, 03:24 PM
Can anyone help me here? My 96 Polaris 425 is popping when I get on the throttle, But it idles perfect. It has no power and just pops. Any help would be appeciated. Thanks
post #2 of (permalink) Old 06-20-2001, 04:56 PM
Re: Engine is popping, HELP
Clean your air filter(or replace). Polaris gets dirty fast, it happened to me.
Yaaah they come to Roost the Rooster oh yaaah, yaaah but he ain't goanna die, he rides the Raptor yah, OH Yaaaaaaah, and he is goanna fly.
post #3 of (permalink) Old 06-20-2001, 11:26 PM
if cleaning your air filter doesnt work try cleaning your carb and checking your jet size
may my zilla live forever
post #4 of (permalink) Old 06-21-2001, 01:29 AM
raptor_rider
If cleaning the carb. doesent help I would make sure the plug wire isnt shorted out to ground , you can check that with the lights off in the shop (garage) and run it (making it pop) you will see the spark jump if it is, if so just replace the plug wire
GOOD LUCK
Ride hard, Lifes short
post #5 of (permalink) Old 06-21-2001, 05:33 AM
Well, I took the filters right out and it still does it, I have cleaned the carb,no better, I do not see any sparks. This is tough. Thanks for all your help. I will keep trying to figure it out. I even adjusted the valves, and still no better.
post #6 of (permalink) Old 06-21-2001, 10:31 PM
raptor_rider
describe this popping more in detail, is it when reving at say 2000 rpm? is it popping out the intake? the exhaust? cold? hot? tell me more!!!
post #7 of (permalink) Old 06-21-2001, 11:12 PM
check for loose and worn through wires also..my warrior had some wires that were worn through and it wouldnt rev at all and would pop...so maybe check that
Large balls...the replacement for displacement[img]/wwwthreads_images/icons/laugh.gif[/img]
<font color=blue>-VVickedVVarrior-</font color=blue>
98Warrior is offline
post #8 of (permalink) Old 06-21-2001, 11:33 PM
Sounds like a bad head gasket to me, had that problem on my old 440EX. GOod LuCk Marc
88 Samurai, 16 V EFI motor, Dana 44's, 36" Swampers, ARB and Detroit
lockers, custom drop arms, GRS II, 5.38 r&p, Warn 8000, custom bumpers,
leather seats & lots more.
post #9 of (permalink) Old 06-22-2001, 06:19 AM
It is just above idle when it starts, but when up get into it, it gets worse. it is more of a flatening out then a pop, but it does pop, does not seem to be out the carb, if you give it full throttle it first goes flat then goes then flat then goes, but won't go if you hold it full throttle, it just bogs. thats the best I can explain it. Thanks again.
Duane
post #10 of (permalink) Old 06-22-2001, 11:34 AM
same thing happened to dude i know, he had warrior. was slightly in reverse and rev limiter was kickin in. the sensor thought it was in reverse. check your hi lo n reverse engagement?
