banshee carbs - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-18-2001, 09:27 PM Thread Starter
banshee carbs
when i bought it the guy said that the carb caps were stripped but they were epoxied so they wouldnt be a problem and like 3 other mechanics said the same thing so i figured it was good...welll i was cruisin today and suddenly the throttle went just about wide open...so i was like frick and hit the ignition switch..it still ran..so i hit the kill switch...it still ran! so i let the clutch out and punched the brakes and got it to stall...looked at it and behold! the right carb cap came all the way loose causing the throttle to come wide open! not good i say! so what can i do about this..the epoxy doesnt seem to work...one thing ive heard of is putting screws thought the side of the caps to hold em down...what do you think about this? i want something that will work so i dont have anyother misshaps...also on top of the carb caps are this big..uhh...thingies...i dont know what they are but they look spiffy! could someone enlighten me on these thingies....oh and isnt the TORS thing supposed to kill the engine if the throttle is stuck wide open? then why wouldnt mine even turn of?!?!? thanks!
Large balls...the replacement for displacement[img]/wwwthreads_images/icons/laugh.gif[/img]
<font color=blue>-VVickedVVarrior-</font color=blue>
98Warrior is offline
post #2 of (permalink) Old 06-19-2001, 01:23 AM
cleartoy
Re: banshee carbs
Get some new carbs. I dont like the idea of the caps flying off at will. Try some 34mmPJs from Kehin.
The TORS should have cut out the ignition if you have the stock throttle. That is the thing on top of each carb.
-cleartoy
Got sand?
post #3 of (permalink) Old 06-19-2001, 08:06 AM Thread Starter
Re: banshee carbs
can i just get new caps? i dont have enough money to get new carbs...
post #4 of (permalink) Old 06-19-2001, 10:24 AM
cleartoy
Re: banshee carbs
I assumed that if the caps were stripped out, so were the carbs. Yes you can get new caps. If you are going to get a Motion Pro Twist throttle, it will come with new standard Mikuni caps without the TORS crap.
-cleartoy
Got sand?
post #5 of (permalink) Old 06-19-2001, 11:40 AM Thread Starter
Re: banshee carbs
i dont believe the carbs are stripped out...at least on the right side the left i havnt looked at beacause it stays on...but if i get new caps with a twist thottle i would fix 2 things at once..cool..
post #6 of (permalink) Old 06-27-2001, 05:12 AM
Re: banshee carbs
If the threads are not bad on the carb just get new caps.
post #7 of (permalink) Old 07-21-2001, 12:05 AM
Re: banshee carbs
Rarely will you see the carbs strip out..the cap is made of pot metal which will give before the carbs will....I cant believe a mechanic would tell you that epoxy would be ok...he ought to be shot!!!!
get new caps....and do it quick!!! ehehehe
AirBorn!!
The good Lord giveth and the Eco-Nazi's Taketh away!
United we stand..Divided we fall..LETS UNITE!
AirBornBanshee is offline
