compression??? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-01-2001, 01:14 AM
compression???
does anyone know the range for compression on a lt500r that is normal i bought a compression gauge and was curious if i need to rebuild my motor
what is normal for any two-stroke motor for that matter
may my zilla live forever
post #2 of (permalink) Old 05-01-2001, 01:23 PM
Re: compression???
Don't know what compression should be. I do know that it won't tell you much about you're 2 stroke. You need a leak down tester. I found plans to make one somewhere on the net about a year ago.
'85 Quadracer
post #3 of (permalink) Old 05-01-2001, 08:43 PM
Re: compression???
It really depends on the engine, I just did a top end on my ktm 350 and got a compression of about 150 psi. Most bikes need at least in the 100's to run, but that is only a general statement. The ktm stoped running at 130.
ktmbk
83 ATC 250r (with many extra parts), 83 ATC 185s, 85 Ktm 350mxc.
post #4 of (permalink) Old 05-01-2001, 09:22 PM
Re: compression???
thanks for the help
my motor is like at 130 the gauge said but the reason i was curious is may dad had some trouble with his lt500r and the gauge said he had 50psi
may my zilla live forever and may my dad's get fixed cause he always wants to ride mine
post #5 of (permalink) Old 05-02-2001, 01:21 AM
raptor_rider
Re: compression???
you have to have ATLEAST 70 lbs of compression for anything to fire
Ride hard, Lifes short
post #6 of (permalink) Old 05-02-2001, 01:40 AM
Re: compression???
My Zilla is rnning 190 psi- the heads been milled, o rniged and polished .the Zilla is so hard to kick over with this much comp but it has a lot more low end torque than any other quad . Mark
Keep the rubber side down!
post #7 of (permalink) Old 05-02-2001, 07:20 AM
Re: compression???
If it only has 50 psi then tear it down and rebuild it. It should have a lot more then that.
post #8 of (permalink) Old 05-04-2001, 07:55 PM
Re: compression???
average compression for a 2 stroke motor is 110-150 psi. The banshee is at about 125-135 normally....so I would assume that the lt500r would be about the same if not a tad bit higher....
AirBorn!!
The good Lord giveth and the Eco-Nazi's Taketh away!
United we stand..Divided we fall..LETS UNITE!
AirBornBanshee is offline
