How long for the break in? What oil/fuel ratio? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-28-2001, 10:06 PM
2 questions for every one. How long does every one break there quad in after top end? My mechanic and I are going to go out and run at least 2 tanks through it before I open it up and see what it really has. I was also wondering fuel oil mixture every one runs to break there quad in and then what mixture after it is all broke in? Thanks for the help.
post #2 of (permalink) Old 04-28-2001, 11:51 PM
Re: How long for the break in? What oil/fuel ratio?
I heard that it was 20/1 after a rebuild, start it up and let it run for a half hour, shut it off and let it cool for 20 minutes, then start it up and let it run for 10 minutes and go(got that from airborn).
WARNING
The surgeon general has determined that motorcycle riding will cause: Swelling of the TESTICLES, shrinkage of the BRAIN, and severe trauma to the EGO.
post #3 of (permalink) Old 04-29-2001, 01:54 AM
cleartoy
I run 24:1 at break in, and 32:1 after.
For a comprehensive step by step break in procedure, go to www.ctracing.com
It is a little overkill, but more of a fail safe.
-cleartoy
Got sand?
post #4 of (permalink) Old 04-29-2001, 10:26 AM
I run the same mix that i intend to use in the bike for the rest of the time i am going to ride it. I ust to use 20 to 1 but I've been told that it may get use to the richer mix and that it's better to do it this way.
I start the bike and let it run for an hour, then turn it off and let it cool down. I check over the bike to make sure everything is good during this, occasionally blipping the throttle to raise the revs and keep the idle a little higher.On the first few rides i try not to beat on it too bad, keeping the revs in their midrange.
Break it in hard and it will always drive strong.
ktmbk
83 ATC 250r (with many extra parts), 83 ATC 185s, 85 Ktm 350mxc.
post #5 of (permalink) Old 05-04-2001, 07:20 PM
Josh, You are close, but I run that 3 seperate rounds....start it up for 10 minutes....let it cool 10 minutes....start for 20...let cool for 10....start for 20 let it cool for 10....then keep it at mellow for the first hour or so then let er rip!!!!
I run same mix at break in as I do for regular run...
make sure at each cool down stage ya check for any damage or leaks....I also after the last cool down, I take out the plugs and check them carefully....
AirBorn!!
The good Lord giveth and the Eco-Nazi's Taketh away!
United we stand..Divided we fall..LETS UNITE!
AirBornBanshee is offline
