Raptor back fires when hot - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-18-2001, 05:10 PM
Does anyone know why the Raptor will back fire and not rev up. It only seems to do this after it warms up. I we let it cool she runs just fine. The air temp here is about 60 F. I am in Japan at sea level. I was thinking jets or timing but this new motor is kinda hard to get information on. So if you can help please help.
post #2 of (permalink) Old 04-19-2001, 01:00 AM
Re: Raptor back fires when hot
fellow Raptor rider
I would have to check the easy stuff first
1)first off check your spark plug mixture reading your plug should be the color of coffee or milk chocolate ,check at different rpms by turning engine off right after doing a test run then pull plug and inspect if your light tan or white worse yet! you need the expertise of re-jetting for your riding conditions.Stock raptors are using a #40 on the left carb & a #45 on the right carb for main jets.I increased mine to a 60 & 65 after doing exhaust and air box modes. It made a major improvement in power and torque.
2)Check your fit of carbs at the manifold some raptors have been known to spit the carbs right off while also backfiring you will find a little spacer on the screw that tightens down the carb you may have to grind off some of that or remove it entirely to tighten the manifold down enough.
3) replace fuel with fresh 92 min octane
4) check your air filter ,is it clean , is it in place.very important the raptor lid must be down all the way to hold the filter in place.
5) after checking some of the easey things yourself call the dealer, especially if under warranty.
Just some things to consider .Mark
Keep the rubber side down!
post #3 of (permalink) Old 04-19-2001, 12:46 PM
initial thoughts, sounds like the choke is stuck...are there any mods to the bike???
AirBorn!!
The good Lord giveth and the Eco-Nazi's Taketh away!
United we stand..Divided we fall..LETS UNITE!
AirBornBanshee is offline
post #4 of (permalink) Old 04-20-2001, 03:06 AM
raptor_rider
I know exactly what it is , I had it happen to mine , there is a vent tube that comes out from between the two carbs , the way it is routed ( looped up under the gas tank ) it gets kinked and wont let the carbs breath , just move it so it doesent have any kinks and I swear all your problems will be gone ( promise )
Ride hard, Lifes short
