Yamaha yfz problem
2.5K views 1 reply 1 participant last post by  Mr_RPM
G
I have a Yamaha 2005 yfz 450.The problem I am having is I have bought a new battery,and with in 2 hours of riding the battery is dead.This is what happened to the the other old battery,so i am sure it not the battery.Since I have owned the quad I have noticed that when I turn the headlights on they flicker with the motor,if I rev the motor the headlights get brighter.Does anybody know what the problem is.Stator,ignition coil
Thank you for any suggestions,
Brian
#2 ·
there are only two mechanical contitions that can cause this, one could be a faulty charging coil(in the stator assembly) or a bad regulator/rectifier. Assuming that all electrical conection are good. To test this you can measure ac voltage prior to the reg/rec conection. if the voltage rises with engine rpms then the culprit is the regulator. The only way to test the regulator is to replace it with a known good unit.
