ATV not Charging - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-04-2008, 07:06 PM
off-road man
Question ATV not Charging
I have a 99 Honda Foreman and the charging light stays on and it runs until the battery runs down.What is the proper steps to test the charging system?
post #2 of (permalink) Old 11-06-2008, 12:36 PM
test a different battery in it and see if anything changes, could just be a bad battery
scott34 is offline
post #3 of (permalink) Old 11-07-2008, 10:21 AM
if not a bad battery then check the stator charge fuse
or the startor could not be sending a charge to the battery
but its probabaly a bad fuse (has happend to me)
but i have had a bad stator and had to buy a new one
if ur lucky ur startor can just have the 1 charge coil replaced and not the whole thing
Mr_RPM is offline
post #4 of (permalink) Old 11-10-2008, 08:43 PM
leroycool1
+1 Mr_RPM
i had the same problem on my honda 300 4x4 and i found a bad fuse
post #5 of (permalink) Old 12-29-2008, 09:29 AM
charging
take a multi-meter and check out put when it is running. you shound have over 13.5 volts when its running. if not your battery will never stay charged. check the plug connections from the stator to the harness.
kawikid is offline
