kfx 700 trouble
I have an 05 kfx 700 that doesn't hit the top end all the way like four hundred rpm shy.It is also slower to rev up than it should be.This is in comparison to three other 700's .I'm at the point of thinking something mechanical in the engine is wrong in the way of timing.The bike has less than forty hours on it. I tried richening it up a little bit but it had no effect.I also checked the valves one was a little tight but not bad.If any body has any ideas or suggestions I would greatly appreciate it.
Thanks Blake
