2002 warrior problems - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-02-2005, 09:48 PM
warrior25
I have a 2002 warrior and it was riding fine for a while, then it started to bog down when giving it half to full throttle. It will start off fine, but once you get half throttle it bogs out. Does anyone know what might be the problem?
post #2 of (permalink) Old 02-06-2005, 02:26 PM
yman
Re: 2002 warrior problems
i had a freind who had one and it was something in the wireing with his if you had the handle bars turned to far it would cut out. but sorry i can't rember exactly what it was.
post #3 of (permalink) Old 02-11-2005, 06:35 PM
You might also check to make sure you're getting good gas to the carb. ie filter? float sticking? clogged venturi?
kstechtom is offline
post #4 of (permalink) Old 02-27-2005, 10:27 PM
tejas
I had the same problem on a older Warrior. Mine ended up being the reverse wire ground being rusty making the ignition act like it was in reverse all the time (safety rev limiter). This wire is green if I remember right(no longer have it) and it goes to the reverse lever. Clean it or ground it somewhere else. Hope this helps ya.
post #5 of (permalink) Old 03-08-2005, 01:30 PM
4WLS
I own a 2001 Warrior, Check the REV limiter sensors in the Clutch/E-brake lever.The 2 wires coming out are your sensors.
Both of mine went bad and the Symptoms were the same as yours. Cost was about $40 and took me about 45 mins.
Good Luck[img]images/graemlins/40BEER.gif[/img]
