see if someone can help me...its worth a try - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-22-2003, 04:00 PM Thread Starter
I have a open air box, 128main, exhuast, K&N w/outerwear, no choke and a 42 pilot jet...
I go through the gears, really hammering the throttle say down a road, and each time I shift, it makes this stutter sound as I hammer down the throttle
it pisses me off when I am going off a jump slow or fast like say in 3nd or 3rd, and want to get that extra boost off, you hit the throttle and it bog, stutters for a second, then goes good...
any sudgestions?
should I run a 40 instead of 42 pilot? or go back to stock pilot?
does it have anything to do with the air/fuel screw?
300EXrider is offline
post #2 of (permalink) Old 07-22-2003, 05:51 PM
Re: see if someone can help me...its worth a try
i would try turning the airscrew out and see if it gets better. if it does drop down a size on the pilot
98Warrior is offline
post #3 of (permalink) Old 07-22-2003, 05:56 PM
sounds like it's slightly rich to me too, I would try the smaller pilot jet too.
Spraguepsycho1 is offline
post #4 of (permalink) Old 07-22-2003, 06:31 PM Thread Starter
I was thinking that, I wanted to run a 40 pilot jet...but he couldnt order those because the company was out, so I have a 38 and 42, I think 42 is supposed to be used in the winter [img]images/graemlins/cussing.gif[/img]
so should I go up on the fuel screw? like 3 1/2 turns out or less?
I think I am going to go back to a 38 pilot
post #5 of (permalink) Old 07-23-2003, 08:03 AM
tony1034
How many turns out are you now? I'd never go past 3-1/2 turns out on a idle-mixture screw. If you turn it in, it will lean it out. Where did you set the needle and how does your plug look?
Tony P.
post #6 of (permalink) Old 07-24-2003, 01:11 AM Thread Starter
well its been stored away, I am going to go out tommaro morning and see what I can do...I will check the plug and everything and then turn it in a bit more...probally to 2 turns...
I will check back in a tell ya how its working...I need to to run nice, I got some parts coming and brand spakin new Kenda Klaw MX tires coming to...wanna get some riding done [img]images/graemlins/cool.gif[/img]
post #7 of (permalink) Old 07-24-2003, 05:37 PM Thread Starter
Well I fixed her up, and is running great...plug was a black color....way too rich...it used to be wet and blakc but I moved it up one clip and turned the air mixture screw out instead of in with the 42 pilot...so now its running strong and took her for a test run, no boggin, sputtering just running great...
thanks, I got more help here then I did at any other site...
