Leaking Gas Tank - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-20-2002, 06:12 PM
Leaking Gas Tank
My friend has a Kawasaki Bayou 220. He noticed over the weekend that his gas tank is leaking gas. It leaks as fast as he can put it in. The gas is leaking out of the tube coming out of the gas tank. What can you do do fix it and is there any way you can stop it???
thanx
post #2 of (permalink) Old 05-20-2002, 06:13 PM
Re: Leaking Gas Tank
Duh!! Buy a new tub from any atv or autoparts store, they are cheap!!!!!
post #3 of (permalink) Old 05-20-2002, 09:05 PM
yeah get a new tube
98Warrior is offline
post #4 of (permalink) Old 05-21-2002, 01:22 AM
I'm afraid you need to be a bit more specific. Is it the petcock that's leaking or is the leak between the petcock and the tank?
If the leak is where the petcock goes into the tank, he'll have to drain the tank & remove it to work on it and apply some sealant around the tank opening where the petcock joins it. I can't recall the name of the sealant that is impervious to gasoline, but any auto parts store will have it. If the petcock itself is at fault, it should be rebuildable.Just disassemble it after drainng the gas. The should be an O-ring or gasket inside that is broken or dried up and not sealing shut.
post #5 of (permalink) Old 05-21-2002, 02:57 PM
I think it is leaking out of the tube right at the gas tank.
