300ex governer!!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-26-2002, 10:57 PM
300ex governer!!!
My buddy owns a 97 honda 300ex It has a governer that kicks in when in reverse or nuetral. how can he rest it so he can go a little quicker in reverse, a little extra is sometimes needed when stuck in the mud!!!!
post #2 of (permalink) Old 04-28-2002, 05:00 PM
Re: 300ex governer!!!
I would suspect that the reverse gear in your buds 300 is a low gear, just like in a car. I personally wouldnt look to rev it out any higher. Youll risk blowing the thing up.
post #3 of (permalink) Old 04-28-2002, 07:20 PM
i am with red on this one. it could and might blow up if u do get it to rev higher. if u do get it to rev higher just watch it.
post #4 of (permalink) Old 05-14-2002, 09:07 PM
just found this on atving.com
Follow the wires that come out of the right sidecase up to the harness on the left side. The wires on mine are light green and white. Unplug the white wire from the harness. Then run a jumper from the harness to a good grounding point. This will disable the rev limiter. The only thing is that this also disables the reverse light. The neutral light still works, but it also stays on when in reverse. Obviously if you are in reverse you SHOULD know it without needing a light to tell you.
98Warrior is offline
post #5 of (permalink) Old 06-10-2002, 06:08 PM
should i do it or just stick with the stock thing?
300EXrider is offline
post #6 of (permalink) Old 06-10-2002, 11:22 PM
raptor_rider
if you want to OVER REV your engine then go ahead and disconect it, but remember HONDA PUT IT THERE FOR A REASON!!!!
