Off-Road Forums & Discussion Groups - View Single Post - Internal vs. External Coil in GM HEI
post #8 of (permalink) Old 11-12-1999, 04:46 AM
Re: Internal vs. External Coil in GM HEI
You can convert between internal and exernal coils, the base is identical[img]/wwwthreads_images/icons/cool.gif[/img]. The tan/red/lighter color wire is power, the brown/black wire is trigger. You can wire it directly to an external coil, I used a 12V model out of an 86 Astro that outputs 50K volts same as the internal coil[img]/wwwthreads_images/icons/smile.gif[/img]. To mount an in-cap coil you need the wiring plug, the center wire (not marked) is a ground wire for the coil. I like the external coil because the cap is so much shorter, with a good coil the perforemance IS the same (I converted when I put on my TBI).
~|_____
__|____|__
/-[img]/wwwthreads_images/icons/smile.gif[/img]||||[img]/wwwthreads_images/icons/smile.gif[/img]-\
([img]/wwwthreads_images/icons/cool.gif[/img])-o--([img]/wwwthreads_images/icons/cool.gif[/img])
Randy 80 CJ5
