Off-Road Forums & Discussion Groups - View Single Post - truck questions?????
post #8 of (permalink) Old 01-02-2003, 01:26 PM
TheJuice
Re: truck questions?????
They are ok to use. 1" is the max though. And to get that much you will also have to loosen the bolt so you can screw it out to put a couple of the spacers under the one nut that is on the bolt. That I am anticipating will require some heat and a big cheater bar, since the torque on that bolt is like 200ft/lbs or so.
1" is all you can add anyway, as there is not enough thread on this bolt to add any more anyway. It is probably best to use this method as sparingly as possible. I already have 4" up front, so the main reason I am adding the extra 3/4" is for proper stance of the truck after adding a winch up front.
TheJuice is offline
