Off-Road Forums & Discussion Groups - View Single Post - CJ - Clocking a D300 - driveshaft mods needed?
post #2 of (permalink) Old 12-23-2002, 04:38 PM
GP'n
Re: CJ - Clocking a D300 - driveshaft mods needed?
You will need to have a new one made, (Tom woods) comes to mind, or a local drive shaft shop can cut and install a new tube on yours. This is usually the least expensive. The best bet is to get it all done and then measure from flat to flat on the yokes. then measure your shaft. To do this compress the slip joint and then pull it out about 1.5" and then measure from center of the u-joint where it would sit on the yoke when installed. if this is the same your in luck if not have the new shaft made to fit these measurements.
GP'n is offline
