Off-Road Forums & Discussion Groups - View Single Post - Installed adjustable prop. valve....same thing!!!!
post #10 of (permalink) Old 12-18-2002, 10:02 PM
Jeeplvr
Re: Installed adjustable prop. valve....same thing
On my CJ the large reservoir goes to the front discs and the small one is for the rear. The reason is that the larger reservoir is needed to supply the large front caliper pistons.
I did a D60 swap in the rear of my CJ and found that the emergency brake cables were a little to short. This made it so that no matter where I adjusted my shoes, the brakes would still lock up quickly.
If you haven’t done so already, try removing your emergency brake cables and see if you still have the problem.
Jeeplvr is offline
