Re: Installed adjustable prop. valve....same thing
absolutely what sarge said!
if you remove the lines from teh master Cylinder, and cover the engine bay with rags, then press the pedal, is there a differnce in the ouputs of the 2 ports?
if so, you need to reverse the lines or get another MC, if not youve got a collapsed line, or trash in the line to teh fronts.
