Off-Road Forums & Discussion Groups - View Single Post - QUADRATRAC 4WD SWITCH ?'S
post #2 of (permalink) Old 12-18-2002, 07:46 AM
Olin18
Re: QUADRATRAC 4WD SWITCH ?\'S
Mine had the same problem when I got it. The switch is vacuume operated. Here is a pretty good guide to trouble shooting it.
With the Jeep on flip the switch with your ear real close. Can you hear vacuume, or air hissing? If you can then the switch has air going to it. That means that the problem is probably between the switch and the X case. Get under the jeep and check the linkage and vac lines running to your Xcase.
If you do not hear air when the switch is tossed then the problem is between the engine manafold and the switch.
Open the hood and find the softball sized and shaped vac canaster on the firewall. Probably right behind the engine. Follow all of the lines running to and from that check for leaks. When you find one, replace that line, and I bet you will be in luck.
Olin18 is offline
