Re: Powerstroke Bronco???
You need a lot more than that to put in a PowerStroke. Powerstrokes are 'fly by wire', there are no throttle cables or linkages, so you'd also have to put in the throttle pedel with it's sensors, the computer, wireing harness, new intake and exhaust, new fuel lines and probably new fuel tanks, new suspension to compensate for all the extra weight. You'd also have to beef up your tranny and get tougher U joints, ??maybe even new drive shafts??. I'm not sure what T-case the Broncs use, but that may need replacing or need to be beefed up. The PSD makes a lot more torque than you gasser does and your 1/2 ton parts just wont hold up.
