Would it be possible for a sagging rear leaf to cause a door not to close? My drivers side door doesn't close unless i lift it as i close it. The hinge bushings aren't worn and it's only getting worse. I rigged it a few weeks ago with a piece of metal in the latch to keep the grabbers from opening so far. That worked for a little while but the spring is sagging more and more and the door won't close now. That's the only thing i can figure cuz they're one the same side. I don't feel like spending $200 on new rear springs so would an add a leaf or helper spring do the trick for now. I don't want to put a ton of money into this truck cuz anything i put lots of money into never lasts. The springs are 2.5 inches wide. They're the stock 2wd springs that came with the truck.
