Off-Road Forums & Discussion Groups - View Single Post - want to convert to 4x4
post #4 of (permalink) Old 11-25-2002, 05:36 PM
86convert4wd
86convert4wd's Avatar
Re: want to convert to 4x4
Get a junk 4X4 truck/bronco. Look for one w/ the same trans/motor to make things simple. My truck was different wheelbase then the donor. You might need the X-member cause the one in the 2x4 was different. ItT was really easy. It only took like 3 days. Heavy but doable with a friend. Getting a donor truck id the easiest way to go though. Driveshafts can be made/adjusted later if you get a donor cheap enought. Swap rears if the ratio is different or you beat the piss out of the T-case. If you need more detail PM me. Good luck.
Also look at the past threads. Someone posted a trans/T-case for sale on Ebay for like $100 or something.
86convert4wd is offline
