Re: Shock mounts-CJ
They did change to a longer mount (forget when) and I do think you have to cut the welded ones off, but you should be able to bolt the longer ones right on. They will let you run a longer shock (more travel). I believe the ford mounts will let you run even longer shocks (if you need that much travel). Good luck.
