Off-Road Forums & Discussion Groups - View Single Post - low compression in #2 only showing 89 lbs
post #7 of (permalink) Old 11-09-2002, 04:13 PM
CJ7Taz
Official Curmudgeon
CJ7Taz's Avatar
Re: low compression in #2 only showing 89 lbs
Well, we have used a modified sparkplug shell to put compressed air into the cylinder. If the air comes out the intake - intake valve, same for exhaust. Air out the oil cap - usually rings, air out the side or the radiator, head gasket. Air out the oil cap can be head gasket. Needless to say, you need to start with on the compression stroke with the valves closed. The air pressure will usually push the piston to the bottom.
CJ7Taz is offline
