Off-Road Forums & Discussion Groups - View Single Post - CJ - Axle swapping, shim and perch ?s
post #1 of (permalink) Old 10-21-2002, 09:16 PM Thread Starter
BMB
I don't recall this being covered, so here goes.
I will be putting a HD20 into the CJ in a SUA setup with 4" lift springs.
Should I leave the shims that came on the springs on them and adjust the pinion angle when putting on new spring perches.
Or
Should I just remove them and adjust the pinion angle when I put on the new spring perches.
The only reason I could think of to leave the shims in is if for some reason I need to adjust the pinion angle in the future, it would be easier to change a shim than to remove and reweld the perches.
BMB
BMB is offline
