Off-Road Forums & Discussion Groups - View Single Post - got a simple question I need answered....
post #4 of (permalink) Old 10-21-2002, 03:03 PM
NCOffroad
Re: got a simple question I need answered....
Have you got a drive shaft spacer? He can use that instead to get the dimensions he needs, probably to turn down the lip to fit inside. Make sure there is clearance for the pinion nut also. If you pull the flange off the third member, you really are supposed to replace the crush sleeve for the proper pinion bearing preload. If you pull one from the t-case, no big deal, just torque it back down and bend the nut lip back into the groove.
HTH
TGT - NCO
NCOffroad is offline
