Re: Hazard Fuse?
I'd start by looking for voltage at the flasher. If no voltage, then work upstream toward the switch. If there
is voltage, then start working downstream. I believe there is a separate fuse for the hazard lights - I can
check tonight. Do you have a manual? I don't use mine all that often any more, the main exception
being dealing with electrical problems.
Later,
Curt
