Off-Road Forums & Discussion Groups - View Single Post - Hazard Fuse?
Thread: Hazard Fuse?
post #1 of (permalink) Old 03-13-2000, 10:00 PM
Hazard Fuse?
I've got an '80 Scout II. The 4 way hazard lights just plain stopped working. When the switch is pushed in, absolutely nothing happens. The flasher's fine; I traded the 4 way flasher for the turn signal flasher and nothing changed (either way; the turn signals worked (and are working) perfectly). I'm thinking that maybe it's a fuse 'cause one of the turn signal wires shorted to ground a couple days ago, and I hit the hazard switch before I realized something was wrong. But is there a fuse anywhere? I couldn't readily find it. If not, what could the problem be? Could the switch be bad? If so, how hard is it to change out? Is it just a matter of pulling the steering wheel and getting to it, or is there something else? I've got a diesel, so I really could use this soon...thanks in advance!
The Warden
1980 International-Harvester Scout II SD-33T
