i have a 79 Scout and I am having trouble starting the vehicle after it warms up. It seems to get the fire but hesitates to turn over. After repeated attempts it finally does but I fear this is flodding the carb and my cause further damage. Any help?
Sounds like it may be the starter solenoid failing when it heats up. When I replaced the starter in my '73 Scout II w/ 304 V8, the starter and solenoid came together. It was cheap but it took two tries to get a good working rebuilt starter. If I had it to do over again I would have put a Delco Remy Starter/solenoid in there. But the second of the cheaper units ($59 as opposed to $89 for Delco) I put in is working fine so far.
There is a procedure on at least a couple of web sites for adding a GM front wheel drive or other starter solenoid in a remote location away from the exhaust manifold. This could do the trick for you, assuming that's the problem.
You might try buying a can of "Circuit Cooler" spray from an electronics store like Radio Shack. After the starter begins acting up, turn the key off and get out and douse the starter solenoid real good with the circuit cooler spray for about 15 seconds. This stuff doesn't conduct and won't hurt anything to spray it on liberally. Cool the solenoide down as much as you can. You may see some frost develop for a moment while you're spraying which will condense rather quickly. This is not a problem. Anyway, after cooling off the solenoid turn the key and give it a try. If the starter/solenoid works after you've cooled it off, then you pretty much know with certainty at that point that the solenoid is bad.
I have a 78 Traveler with a 345 that had the same problem.(I live in PHX AZ). My mechanic put in a solenoid on the front of the firewall near the top of the engine compartment , and it's worked fine since. I think he used a ford pick-up solenoid, but don't tell anybody! Bob Knotts
My Scout just started starting hard when warm this weekend, and the problem was an insufficient ground between the engine block and the body, I would definently check this out and suggest that the cable be the same size as your battery cable.
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
