Off-Road Forums & Discussion Groups - View Single Post - Dip Stick Problem<<-----UPDATE--->>
post #2 of (permalink) Old 09-26-2002, 08:52 AM
Re: Dip Stick Problem
A new dipstick is around $8 from the STEALERSHIP....
The only bad thing is.. it's a press fit into the block and can be done... I did it about a month ago...
it is best to remove the pan and back out the tube. Some have had luck trying to pry it out from the block , but I never have.
Once you have the old tub out... look carefully at the bend in the new tube... it must be aligned with the pan properly to allow the dipstick to full seat... if not you will be bouncing the dipstick off the splashguard built into the pan. This is another reason I like to remove the pan... proper alignment.
