Re: ARB versus Detroit Locker???
I also went with the Detroits in the front and back. I like the idea that i know it is locked all the time. Also that there are no accessories that go along with it, to break or wear. Unlike the ARB you have the air lines that either get snagged by debris unless route properly. Depending on your elevation, sometimes water will form in the air lines and will drop in to your diff. Then you have to make sure that the air compressor is in tip top shape. I run my as a daily driver/weekend rockcrawler. I have had no problem with the detroits on the street. I also run 35 inch tires and when four wheeling down hill its nice to have the twin stick option. I went with the Atlas t/case for the twin stick. Then you save money between the both the detroit is cheaper and you know how bulletproof and dependable it is to you in the long run.
