Off-Road Forums & Discussion Groups - View Single Post - 93 wildcat efi problems?
post #2 of (permalink) Old 01-30-2000, 10:39 AM
Re: 93 wildcat efi problems?
My 98 has the same problem. I thought it was bad fuel and ran some alcohol and it went away but when I cleaned my tank I noticed the pickup filter off. got it back on and am trying to figure out how to check the injectors. After reading your post I might be chasing the wrong problem. This year I put a d&d pipe chip and v-force reeds on. I also went to a lightwieght can. After cleaning the tank I noticed a hole in the can side where the bracket is welded on, about the size of a nickle. I put the stock can back on and now it idles smooth and much quieter. I just wonder if with the reeds and little or no backpressure it was messing the cpu up and sending false readings. i guess I'll find out next weekend, But I'd still like to know how to check the injectors to make sure they are really clear. I used to check my carbs every year. Let us know if you have found out anything
craig
