Off-Road Forums & Discussion Groups - View Single Post - YJ steering shaft removal
post #3 of (permalink) Old 09-15-2002, 06:22 AM
sas87yj
Re: YJ steering shaft removal
the shaft can rust up and not collapse. you can try spraying pb blaster up the slip-joint but it really needs to be upright and let the juice fall down in the shaft slip-joint which means you gatta get it out first. take the gear box off- don't remove the lines so you won't have to bleed. pb blast all the gear box bolts too. once you get the shaft out, you can spray it down good and let it set. mine broke loose and it collapses fine now. i put on a borguson shaft while i was at it and have the stock for a spare.
