Off-Road Forums & Discussion Groups - View Single Post - Need some tech info
post #7 of (permalink) Old 08-31-2002, 10:36 PM
jbsjunk
Re: Need some tech info
if the manifolds are in good shape, won't hurt to try. as for hop-ups, normal stuff still works on this. cam should be a no-brainer, pistons may be special because of the longer con-rod. intakes don't exist for these engines unless you use spacers from wieand.
in your case, all you want mainly is bottom end torque, if the engine runs fine as-is, try it then see where you want to go next, (little bigger cam, etc).
keep us posted!
jbsjunk is offline
