Off-Road Forums & Discussion Groups - View Single Post - Driveshaft swap: Dana 20 TC to Dana 35 rear end
post #2 of (permalink) Old 08-29-2002, 01:06 PM
AllLockedUp
Re: Driveshaft swap: Dana 20 TC to Dana 35 rear end
You should be able to use a CJ shaft, most likely it will have to be cut to length. Your other option ($$$) is to have a shaft made to your specs - you could get either a CV or a high-travel slip shaft. There may be a driveshaft shop local to you that can make you anything you want, or you could use an internet source like Tom Woods.
It really depends on how your rearend is setup and the angles that you'll be dealing with.
AllLockedUp is offline
