Re: lift
You dont really say what you are driving or what size tire you are lookin to run. I used full length AALs for a little lift and to stiffen up the suspension on mine and was able to fit 31 x 10.5s with a litlle clearancing on the rear quarter panel. Depending on your gearing I wouldnt go much bigger and expect to tow that much. I pulled 4000 lbs regularly w/o problems but it would work a little harder climbimg up steep grades.
<-<-<- heres a pic
