viberating rearend
A friend has a sammy with 513 trakker gears front and back the rear is welded and the front has a locker.The rear welding job was done extremly well.The problem he's having is that under a load its sounds as if something is thumping we havent opened it up yet to look around.You can travel down the road at any speed the second you clutch or let off the gas the noise and vibration stops.Has anyone got any clues.
