Re: Oil up the Valve cover case vent tube
I'll bet your oil level is OK. Your engine has a hose going from the valve cover to the air filter housing with a hose teeing off and going to a fitting on the rear left side of the block. The fitting on the block is PVC valve. Replace the PVC valve then replace the hose between the PVC valve and the tee it is often plugged with oil sludge. Can also clean out the sludge in the hose usein solvent and poking a wire though the hose.
