Off-Road Forums & Discussion Groups - View Single Post - steering shaft
Thread: steering shaft
post #1 of (permalink) Old 10-17-1999, 08:20 AM
steering shaft
One of my friends broke his stock steering shaft coupler on friday night, we were going to put it back together with a Pto U-joint like my truck
has, but the place that sells them was out of stock and they were backordered..So to the self serve junkyard we went..I looked
at every vehicles steering shaft, and found that some not all chevy vans com with a double u-joint with a slip shaft in between them.
One side is 3/4 with a notch and a flat spot..the others is 1" flatted shaft..To match the flatted shaft I grabbed a steering shaft from
an Amc gremlin..I took the stock joint, removed the guts, a 3"piece of sched 40 1" steel pip and reduced its outside diameter .010 to fit inside the stock joint and press fitted it into the stock joint. I then cut the gremlin shaft to give me 3 inch of 1"(OD)round plus the 1" of of square(it transitions into
the square) reduced its wall about .005 and press fitted it into the the 1 Sched 40 pipe already in the stock joint..this gave me the flat
to slide into the gm ujoint assembly..so on it went, i marked for the through bolt notch and notched the 1" flat with the die-grinder..
then inserted the bolt and tightened..I then cross drilled the stock joint box at 90 degrees and bolted through the 1" sched 40 and 1" od
and put 2 grade 8 5/16 bolts though it.. Then I took the assembly out to the truck pinned it onto the steerin box and marked where
the new u joint assembly meets up with the upper part of the stock shaft, after cutting it to lenght, I ground the required flat spot on it
and the notch for the clamp bolt, and of course bolted it together..I installed it on the truck..No binding, no play, just tight steering
I wish I had a digital camera around here still.. Total cost not including tools was $9.32(including tax). required tools Is a good saw
like a sawzall ,chopsaw or bandsaw, a drill press(or drill if you are good with one) and a diegrinder. I used my lathe to turn the pipe
down but a die grinder can be used to fit the pipe , I used it for the clamp notches though.. Once painted the piece looks totally
factory..Its trick enough that I am going back to the junkyard today to get enough shafts to biuld 4 more..Maxt
