Off-Road Forums & Discussion Groups - View Single Post - weird volt meter readings
post #4 of (permalink) Old 04-19-2002, 07:19 AM
Jim_Lou
Re: weird volt meter readings
On some alternators there is a wire that runs from the output lug to a connector an inch away on the alternator housing. This carries output voltage to the internal regulator. If the connection gets loose or corroded the regulator will see low voltage and kick up the output, causing the symptoms you describe.
Jim_Lou is offline
