Off-Road Forums & Discussion Groups - View Single Post - Distributor
Thread: Distributor
post #10 of (permalink) Old 04-15-2002, 01:56 AM
Junk Yard Genius
Re: Distributor
*I going to be replacing my distributor in a 77 304. I was wondering if there was a good
distributor upgrade I could do. I can get another stock distributor rebuilt for 60 bucks. I
dont want to spend a lot of money.*
'77 is a Prestolite ignition, and it's not what I'd recommend of you want reliability, ease of parts replacement, and performance.
There is a quick and easy way to do your ignition, but it's going to cost about $250.
You need a wiring harness. I have one for $70 dollars with instructions.
As far as I know, I'm the ONLY one with this harness, and if you price just the connectors alone, you will find this is a good deal.
You will need a distributor from a '79 Jeep CJ-7 with 304 V-8 engine.
It will drop right in your engine, and work just GREAT compared to the Prestolite you have now.
(Use the Prestolite as a core and save your self about $50.)
From '79 Ford F-150 pick up with 302 CID V-8 Engine...
You will need one each of the following...
Ignition module. Between $15 and $50 depending if you buy at the discount parts houses or NAPA...
Distributor Cap Adaptor. $5.
Distributor Cap & Rotor, Buy premium quality with brass terminals About $30
From a '90 302 V-8 Pick up with E.E.C....
Plug wires, The jury is still out on what fits best, but anywhere from $20 to $80
(MSD 8.8MM are the best quality wires, but they are expensive)
From a '92 Ford Escort with 4 cylinder engine, the Ignition coil, $15 to $50 depending on quality.
Coil Connector from NAPA, P/N ICC-1, $13.
<hr>
If you can find a Ford in the bone yard you can swipe all this stuff off of, MORE POWER TO YOU!!!
Advance Auto has the distributor for about $90, and the rest of the stuff is Ford factory.
Don't forget to give them the Prestolite back as a core, it's worth about $50 when you are done.
Here is the wiring diagram if you find the parts and want to wire it your self...
Junk Yard Genius is offline
