Off-Road Forums & Discussion Groups - View Single Post - BDS install quesiton
post #2 of (permalink) Old 03-02-2002, 11:57 PM
CJ7JeepOffRoad
Re: BDS install quesiton
Yes you will probably have to take your brake line apart to install the drop bracket, If it is only a 2" lift than I would only use the degree shims, you can take the center pin out and put it therw the shim or you can drill the shim out so the center bolt will fit! Good Luck:
Rodney C
CJ7JeepOffRoad is offline
