Off-Road Forums & Discussion Groups - View Single Post - Another EGR valve question...(more info)
post #6 of (permalink) Old 02-26-2002, 11:11 AM Thread Starter
Dan 84 CJ-7
Re: Another EGR valve question...(More info)
Well..my assumptions based upon my test mentioned above are not enough to consider the valve bad. I stopped by NAPA this morning and a brand new EGR valve had the same behaviour...holding a finger tightly over the vacuum inlet of the valve seemed to make no difference in the resistance of pushing the diaphragm.
I have watched for movement of the valve on the vehicle and there is none, that's why I originally thought the valve was bad. I picked up a hand vacuum pump today, so I will try applying some vacuum to it tonight and see if it moves.
I may just go in for the test with the EGR vavle as it is...might just pass with my recent re-jetting of the carb.
Thanks for all the help and suggestions.
Dan 84 CJ-7,Weber,HEI. 95 ZJ,V8. http://www.cableone.net/wdohrn
Dan 84 CJ-7 is offline
