where does it go?
Hello fellow FSJers.
Question. My 1970 J-3000 Gladiator Buick 350 came factory with manual brakes. I upgraded to power using all original Jeep parts (lower pedal, booster mount, master cylinder). The master cylinder and booster are now where the window washer fluid bag hung. Where did they put the washer bag on power brake models with the 350?
Also, the master cylinder has the outlets for the brake lines facing the engine. I had to remove the stove from the exhaust manifold to the air cleaner to make room for the brake lines. Did 350 models with power brakes have a different air cleaner/air stove setup? adifferent master cylinder with lines facing the fender?
thanks for the help
