Off-Road Forums & Discussion Groups - View Single Post - Another EGR valve question...(more info)
post #2 of (permalink) Old 02-24-2002, 08:51 PM
TiminMb
Re: Another EGR valve question...
Hope I'm not insulting you with this, but you know that at idle ported vacuum is nil, and it peaks when you open the throttle partly. So you will have to work the throttle to get it to open the egr. Or you could test it using manifoold vacuum, that should give you at least 25 HG of vacuum.
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, 4.56's and Detroit softlocker, full cage & belts, Xenon flares, Dana 44 rear, GM dual diaphragm brake booster
TiminMb is offline
