Off-Road Forums & Discussion Groups - View Single Post - Holley Jetting?
Thread: Holley Jetting?
post #7 of (permalink) Old 01-10-2002, 06:09 PM
Re: Holley Jetting? + fuel pressure? more info
OK Team Rush here is some more info before you ask. My float is set so that ther is just barely fuel coming out the sight hole, but I will correct that as soon as I finish writing this. The idle air mix screws are both turned evenly at 1 full tun from being bottemed out. the acc pump clearance is set to .015 and is running a # 28 squirter jet. my accerator pedal works fine beging to end with no interferance between linkage, or air cleaner. The acc pump squirts throught the entire range of pedal depresion, there are no more vaccum leaks. I am running 2 filters. the dist is hooked up to the center front port and the PVC to the rear port. And lastly the number stamped on the air horn is 4412-3 and then directly underneath that number is 2771. Thanks for you time and expertise.
Jon
84 Toy,72 CJ5,91 RM125
[email protected]
